Part Time Light
if it's totally random, you've got a short. if coming on when in 4x4 i'd say maybe vacuum is activating the switch. You could unplug the wire going to the switch under the pressure tank and see, or follow your vacuum line from there out and see if the vacuum line still goes to the back of the transfer case
Of course, the light is there to remind you you're in 4WD. If the light is coming on when you're in 4WD, that's what it's supposed to do. What's the problem?
No problem its just that light just started coming on and i have been driving the jeep and using 4x4 for like a year so i was just wondering what it meant
Thanks guys i just think its weird that it just started doing it
