comancheMJ Posted February 18, 2013 Share Posted February 18, 2013 I got a 1986 Jeep Comanche 5 Speed with AC, Power steering, with the serpentine belt, it is NOT the twin belt set UP. I can not find a new pulley & Power steering assembly for this application. Does anyone know what other jeeps are direct bolt on for a smooth replacement? Reason is because my pulley got bent and the Serpentine belt falls off every time on start up. Any help is Very Much Appreciated. Thanks ;p Link to comment Share on other sites More sharing options...
comancheMJ Posted February 18, 2013 Author Share Posted February 18, 2013 I compiled a list of interchangeable parts for my 2.5 liter 1986 Comanche. Is this Accurate if I want to get a power steering pump>?? 1983-1986 Jeep CJ7 4Cyl. 1987-1990 Jeep Wrangler 1984-1986 Jeep Cherokee 1986 Jeep Comanche 1983-1985 Jeep Scrambler 1984-1986 Jeep Wagoneer Link to comment Share on other sites More sharing options...
jimoshel Posted February 18, 2013 Share Posted February 18, 2013 Sounds like somebody may have done a engine swap, dropping in a later year engine.Any year 2.5 from a '87 up should work. "86 was the last year for V Belts in the XJ-MJ, with "87 using the serpentine. Link to comment Share on other sites More sharing options...
comancheMJ Posted February 18, 2013 Author Share Posted February 18, 2013 It is the renix based TBI 4 Cyl. With Bendix CPU. Link to comment Share on other sites More sharing options...
MJRemi Posted February 18, 2013 Share Posted February 18, 2013 You said the reason is due to a bent pulley. If you don't need the pump replaced, take the pulley to NAPA or the Stealership and have them help you find the match. If you need the pump assembly, I saw a bunch on Rockauto and local parts stores probably can get them as well. I saw one on ebay for 84-86 but it was a two-belt pulley. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted February 18, 2013 Share Posted February 18, 2013 I had same issue. The dealership was able to get one through their vintage parts connection. It may still be available. I bought mine a few years ago, so theres really no telling without trying. Link to comment Share on other sites More sharing options...
comancheMJ Posted February 18, 2013 Author Share Posted February 18, 2013 On 2/18/2013 at 1:16 PM, dasbulliwagen said: I had same issue. The dealership was able to get one through their vintage parts connection. It may still be available. I bought mine a few years ago, so theres really no telling without trying. I will look into that. Thanks :P Link to comment Share on other sites More sharing options...
comancheMJ Posted February 18, 2013 Author Share Posted February 18, 2013 On 2/18/2013 at 6:47 AM, MJRemi said: You said the reason is due to a bent pulley. If you don't need the pump replaced, take the pulley to NAPA or the Stealership and have them help you find the match. If you need the pump assembly, I saw a bunch on Rockauto and local parts stores probably can get them as well. I saw one on ebay for 84-86 but it was a two-belt pulley. I am unsure if it is just the pulley that is damaged or the screw tightened to keep it secure. So I want to be safe and order a whole new pump, pulley, What type of tool do you use to remove just the pulley from the power steering pump? Link to comment Share on other sites More sharing options...
MJRemi Posted February 18, 2013 Share Posted February 18, 2013 A pulley puller tool from Autozone or similar parts store. They charge a rental fee and then refund it when you you return the tool. Link to comment Share on other sites More sharing options...
comancheMJ Posted February 20, 2013 Author Share Posted February 20, 2013 On 2/18/2013 at 4:35 PM, MJRemi said: A pulley puller tool from Autozone or similar parts store. They charge a rental fee and then refund it when you you return the tool. Thanks! I am still looking for the right setup!!! Any aftermarket brackets from Spectre you think would work>>? I.E. SPECTRE 4123 http://www.spectreperformance.com/index.php/ps-bracket-pulley-kit-sbc-lwp-chrome-aluminum-pulley.html Link to comment Share on other sites More sharing options...
comancheMJ Posted February 20, 2013 Author Share Posted February 20, 2013 New pump Ordered W/ RESERVOIR. ACDELCO 36716317 Now I am Seeking the Pulley....It is a 6 groove with the number stamped on the front of the pulley " 3238275". If anyone knows where I can get a N.O.S without going to the dealership. I want O.E.M!:P Link to comment Share on other sites More sharing options...
comancheMJ Posted February 20, 2013 Author Share Posted February 20, 2013 I may experiment with this and see how this works... Down fall it is plastic. On the bright side it is the six groove and dimensions of this would be good to know. Might be one of those no other option deals before I go to the next extreme. http://www.ebay.com/itm/Dorman-Power-Steering-Pulley-Serpentine-6-Groove-Plastic-Black-Jeep-Dodge-Each-/330862675500?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&hash=item4d08f3c62c&vxp=mtr Link to comment Share on other sites More sharing options...
a.e. Posted February 27, 2013 Share Posted February 27, 2013 check out a dorman part# 300-301 a napa should carry them Link to comment Share on other sites More sharing options...
