comancheMJ
Everything posted by comancheMJ
  1. I may experiment with this and see how this works... Down fall it is plastic. On the bright side it is the six groove and dimensions of this would be good to know. Might be one of those no other option deals before I go to the next extreme. http://www.ebay.com/itm/Dorman-Power-Steering-Pulley-Serpentine-6-Groove-Plastic-Black-Jeep-Dodge-Each-/330862675500?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3AJeep&hash=item4d08f3c62c&vxp=mtr
  2. New pump Ordered W/ RESERVOIR. ACDELCO 36716317 Now I am Seeking the Pulley....It is a 6 groove with the number stamped on the front of the pulley " 3238275". If anyone knows where I can get a N.O.S without going to the dealership. I want O.E.M!:P
  3. Thanks! I am still looking for the right setup!!! Any aftermarket brackets from Spectre you think would work>>? I.E. SPECTRE 4123 http://www.spectreperformance.com/index.php/ps-bracket-pulley-kit-sbc-lwp-chrome-aluminum-pulley.html
  4. I am unsure if it is just the pulley that is damaged or the screw tightened to keep it secure. So I want to be safe and order a whole new pump, pulley, What type of tool do you use to remove just the pulley from the power steering pump?
  5. I will look into that. Thanks :P
  6. It is the renix based TBI 4 Cyl. With Bendix CPU.
  7. I compiled a list of interchangeable parts for my 2.5 liter 1986 Comanche. Is this Accurate if I want to get a power steering pump>?? 1983-1986 Jeep CJ7 4Cyl. 1987-1990 Jeep Wrangler 1984-1986 Jeep Cherokee 1986 Jeep Comanche 1983-1985 Jeep Scrambler 1984-1986 Jeep Wagoneer
  8. I got a 1986 Jeep Comanche 5 Speed with AC, Power steering, with the serpentine belt, it is NOT the twin belt set UP. I can not find a new pulley & Power steering assembly for this application. Does anyone know what other jeeps are direct bolt on for a smooth replacement? Reason is because my pulley got bent and the Serpentine belt falls off every time on start up. Any help is Very Much Appreciated. Thanks ;p
