8.8 rear help
hey guy...i came across a great deal on a 4.10 LSD 8.8 and also a M.O.R.E. install kit so i plan on installing it in my MJ shortly....
My main concern is the brakes....what do i have to do exactly to get everything to hook up correctly and what upgrades or modifications should i do to get the best stopping performance
all your help is always appreciated
As far as the hydraulic brakes. you can just hook up, bleed and go. A disc brake MC would be nice but not necesary.
As to the Emergency brakes. They are actuated with a lever. In my TJ (W/8.8 ) I had a buddie fashion me two pieces of steel with a slot for the lever, and a hole drilled thru for the cable. I used my factory cables, cut the ends off. Pushed them thru the hole and put that slot over the lever. I drilled and tapped a couple holes for set screws to hold everything tight.
Hard to describe on line and I cannot seem to find my pics.... :oops:
Good luck,
CW
ok cool just checking to make sure....now i heard that the pumpkin is offset more on my 8.8 than the d35 will this effect anything...we are just gunna make sure the driveshaft lines up correctly and measure where the new perches go and weld them on....see any problems with this....just trying to do this correct the first time lol
I just did mine and it looks ok the drive shaft offset to the passenger side, and I have seen no issues but then again I don’t have mine all the way done ether. But as far as I can tell there is no issue. If you search this there has been a lot of talk about the 8.8 lately must be something in the water.:nuts: But yeah just set you pinion angle at what you want and weld on some spring perches and there you go.
Yet Scott's Isuzu swap is what intrigues me :nuts:
Just make sure you use new U joints in the driveshaft and the pinion angle is properly set. The minute Offset won't hurt anything.
We have a master cylinder mod that you may be interested in after you get it all done.
