Timmmmmy Posted January 21, 2013 Share Posted January 21, 2013 Hello, I just picked up my Rough Country Cherokee front bumper for my MJ. It looks like I will have to trim the forward portion on the front fenders and plastic trim flush with the bottom of the front clip/header for it to fit. I have never trimmed metal before and want to make sure I do it properly. Should I simply cut it flat or roll the edge over? I have tried searching online and on CC for a write up doing it as well as removing the front bumper and skirt but haven't found much. If you know of a good link it would be much appreciated. Thanks, Ryan. Link to comment Share on other sites More sharing options...
ratrapp Posted January 21, 2013 Share Posted January 21, 2013 i just cut mine flat with a sawzall.i worked very slowly as not to to jerk the fenders and didn't use a cutoff wheel tool or it would've burnt the paint. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 21, 2013 Share Posted January 21, 2013 If you cover the area with tape...to keep the paint from chipping as you trim. You can use a sawz-all or a jig saw with a fine tooth blade. Link to comment Share on other sites More sharing options...
johnnyc Posted January 21, 2013 Share Posted January 21, 2013 An air nibbler works great. Then I used some black door moulding to cover the cut edge. Link to comment Share on other sites More sharing options...
Alexia Posted January 22, 2013 Share Posted January 22, 2013 Cut with a little extra metal over hang and roll the edge for the professional look along with extra strength. That or just cut it will work! Link to comment Share on other sites More sharing options...
Timmmmmy Posted January 22, 2013 Author Share Posted January 22, 2013 Thanks guys! Link to comment Share on other sites More sharing options...
