Fs: Southern Maine: '88 Comanche 4X4, Ax15 4.0
Fezzik
I am going to have to sell my comanche, It has sat around to long while I try to get the money to fix it up, and everything else always comes first, I just think it is in too good of a condition for a NE truck to sit.
The Good (what I have done in the last 2 years)
-New gas tank
-external slave AX15 with matching transfer case and crossmember from 95 cherokee, new master at the time
-Brake booster from same cherokee included but not installed
-Side view mirror from 95 cherokee that have manual adjusters in the cab
-New rear brake lines
-New ebrake cables- 2 front and I believe pass rear
-Valve cover from 97+ with updated PCV system
-2 sets of tires mounted
-new track bar
-new tie rod ends (I believe)
-Was painted about 5 years ago with new decals
-New 110 amp alternator
-new battery
-4 new speakers
-cheap Aftermarket single CD player
The Bad
-Vibration, starts around 55, doesn't get too bad, I think I've narrowed it down to shocks, hence the 2 sets of tires and wheels
-Headliner covering is missing, but board is still intact
-drivers floor pan needs to be fixed due to rust
-Bed has some rust on inside passenger side just in front of wheel well
-Lower edge of tailgate is all rusty
-No A/C
That's all I can think of for now,
Pictures are at this link, sunny ones are from the summer, snow ones are newer, toolbox and backrack are not included
http://s5.beta.photobucket.com/user/MEZR2/library/88%20MJ
I'm asking $1000
Currently registered, but that could change at anytime
Greg,
I don't know which ones were you, there were only a couple I didn't answer and they were simple do you still have it emails, I did want to update here that I have someone coming tuesday who will probably take it home. I will update then
Archived
