HOrnbrod Posted January 10, 2013 Posted January 10, 2013 Here's something I've never done. I need to remove the two rectangular air vents circled in RED in the pic below. How to get them out w/o breaking them? Thanks. Image Not Found
Biotex Posted January 10, 2013 Posted January 10, 2013 They should pop out seperately of the surrounding chamber. I believe they pivot on the top and bottom center. That is the area to spread taller to pry it out.
mjeff87 Posted January 11, 2013 Posted January 11, 2013 Don, slip a small screwdriver or similar object between the top of the vent and the dashpad in the center about 1/2" and press downward while gently pulling the top of the vent forward. Once you see the pin/pivot thingy that attaches it you'll understand how it works. There's a pin/pivot at the top and bottom. Be careful, with age they become pretty brittle. Jeff
HOrnbrod Posted January 11, 2013 Author Posted January 11, 2013 Thanks Jeff. Found this pic over on NAXJA. UB exacerly right. :cheers:
