xjustinx Posted January 8, 2013 Share Posted January 8, 2013 So I bought an 89 Comanche with a lift and who ever put the lift on had the bright idea to hack the front bump stop mounts off half way. Was wondering what way I should go about fixing this. Just reweld a pipe over the existing one? I can get a pic tomorrow of the situation. Link to comment Share on other sites More sharing options...
mnkyboy Posted January 8, 2013 Share Posted January 8, 2013 You could make some from tube or just go the junkyard and cut some off an XJ. Link to comment Share on other sites More sharing options...
Eagle Posted January 8, 2013 Share Posted January 8, 2013 You could make some from tube or just go the junkyard and cut some off an XJ. Cut? Why cut them off? They just unscrew. Link to comment Share on other sites More sharing options...
mnkyboy Posted January 9, 2013 Share Posted January 9, 2013 He says the mounts were cut off ,not the stops themselves. Link to comment Share on other sites More sharing options...
xjustinx Posted January 9, 2013 Author Share Posted January 9, 2013 yeah just a sloppy cut job Link to comment Share on other sites More sharing options...
Comanche County Posted January 9, 2013 Share Posted January 9, 2013 That metal is pretty thick. You can cut some others off and weld em up. You could even add a bit of length to them also. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted January 10, 2013 Share Posted January 10, 2013 Where are the pics? Link to comment Share on other sites More sharing options...
xjustinx Posted January 14, 2013 Author Share Posted January 14, 2013 Link to comment Share on other sites More sharing options...
Eagle Posted January 14, 2013 Share Posted January 14, 2013 He says the mounts were cut off ,not the stops themselves. Aaaarrrggghhh! Missed that. My bad. WHY oh why do people do things like that? Link to comment Share on other sites More sharing options...
xjustinx Posted January 14, 2013 Author Share Posted January 14, 2013 Aaaarrrggghhh! Missed that. My bad. WHY oh why do people do things like that? Beats me, but I think I may have come up with the fix. I'm gonna recut the hack job so its even then weld a washer with a captured nut onto the post so I can mount a generic bump stop. Then to take up the rest of the space I'm gonna get prothane spring inserts. I think that will do the trick. Link to comment Share on other sites More sharing options...
mnkyboy Posted January 14, 2013 Share Posted January 14, 2013 I would make sure to make the stops the correct length if you're truck is ever going to go offroad, even with full length stops my truck can just about spit out a 6.5" lift coil at full flex. Link to comment Share on other sites More sharing options...
