Dana 30 Noise In 2Wd That Goes Away In 4Wd Diagnosis Needed
I am doing a 2wd to 4wd conversion on my 86 comanche.
When I test drove it I am getting a wierd noise in 2wd that goes away in 4wd. It sounds like a gear is trying to engage into another gear. I also am getting a knocking noise when turning which sounds like a bad axle u joint or one hitting.
Observations:
Right steering knucle did not seat as well as the left side although I installed new split seat in the new steering knuckle.
Installed new Axle U joint in right Axle shaft- I had difficulty installing it as it seemed as though the u joint was a bit wider in one direction than in the other.
Any tips or special installation instructions when installing a right axle with a Dana 30 command trac front end?
Thanks in advance for any tips and assistance.
Doug
When I put it in 4WD and the command trac engages then the noise goes away even without the drive shaft installed.
I've seen this twice on 86 vintage XJs when I was at the dealership.
The axles were jigged wrong and the axle tube was actually going into the diff area at a slight angle. There's a little bearing in there that the axle turned on and it would howl until 4wd was engaged.
Passenger side axle is in 2 pieces. Where they meet, there's a little pilot type bearing. When in 2wd, they are going different speeds and the bearing howls. In 4wd, they're both going the same speed since they're locked together. No noise.
  • 1 year later...
Long story on solving this problem.  Ended up learning that the axle was bent and the disconnect axle was significantly worn.  I tried a solid axle replacement and ultimately replaced the front differential for a non disconnect model.  Noise definitely gone now.  What a pain it was!
