As a new Comanche owner in San Jose, CA, I was just wondering if any other owners in the area had mechanics they trusted and could recommend?
Thanks!
The check engine light is on with P0132 and P0135 codes. The engine runs fine. Looking at other forums, I have seen suggestions to change the front bank O2 fuse and the O2 sensor itself if the fuse doesn't work.
That being said, the guy I picked it up from thought it might have to do with a missing vacuum component that was left off when the 99 cherokee engine was put into my 87 Comanche. So my thinking was: I will try replacing the fuse and then the sensor, but if that doesn't work, take it to a shop. Because CA law requires that I get it registered within 10 business days of purchasing it, and because I don't think I can get it registered with the check engine light on, I don't have too long to work on it myself.
SYMPTOM
P-0132 1/1 O2 SENSOR SHORTED TO VOLTAGE
WHEN MONITORED
With the engine running for more than 2 minutes and coolant temperature above 170 degrees F .
SET CONDITION
The oxygen sensor voltage is above 1.2 volts .
POSSIBLE CAUSES
  • O2 sensor 1/1 wiring harness intermittent defect
  • O2 sensor 1/1 wiring harness observable defect
  • Signal circuit shorted to voltage (at PCM)
  • Signal circuit shorted to voltage (wiring harness)
  • O2 sensor 1/1 connector terminal(s) observable defect
  • O2 sensor defective 1/1
  • PCM connector terminal(s) observable defect
  • PCM defect (1/1 O2 sensor)
SYMPTOM
P-0135 1/1 O2 SENSOR HEATER FAILURE
WHEN MONITORED
With the engine at idle immediately after a cold start (engine < 147 degrees F and battery temp ±27 degrees F of engine temperature).
SET CONDITION
O2 sensor voltage > 3V for 30 to 90 seconds
POSSIBLE CAUSES
  • 1/1 O2 sensor connector damaged
  • 1/1 O2 sensor ground circuit open
  • ASD relay output circuit open
  • 1/1 O2 sensor failure
  • 1/1 O2 sensor heater element failure
  • 1/1 O2S heater failure does not reoccur
Hmmm. I'd say the first O2 sensor was bad. $8.00 at Rockauto.
