1991, jeep, comanche, sport truck
4.0L H.O/ 5spd AX-15 / NP231 / Dana 30 / Dana 35 / SWB
Build date: the panel is worn out and i can't read it
Current Location: Abbotsford British Columbia Canada
Status: still on the road running strong 215,000KM on the ODO sporting a bit of cancer.
Notes: white exterior with sport truck decal on the side, burgundy interior, with floor shift, no carpets, 4x4, has a decent bit of fixable cancer, the driver rocker is %60 rusted out, and the driver floor is almost gone (patched with fiberglass still the spring time)
Current owner: I'm the current owner
  • 6 years later...
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-H9
125 Zone 25-Canada-Alberta
1AB Canada Dealer Retail
3N8 Drive Away Program Tracking
4HA Special Scheduling Condition I
ACA EASY ORDER PACKAGE ACA
ALA SE Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKA Carpets - Floor and Cargo Area
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DHN Command-Trac Part Time 4WD System
DJH 230MM Front Axle
DMM 3.07 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRZ Left Remote Mirror
GSZ Right Remote Control Mirror
GTZ Manual Remote Mirrors
HCD Do Not Use - See HCA
JAY DO NOT USE - See JP, KA classes
JDB 180 KPH Primary Speedometer
JGB Digital Clock
JHA Var Intermittent Windshield Wipers
JJA Cigar Lighter
K3Z STRIPE/BADGE/MOLDING/COLOR
KDN
KWS STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
LMK Daytime Running Headlamps, High Beam
MB1 Black Front Bumper
MBJ Black Powder Coated Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NHK Engine Block Heater
PW7 Bright White Clear Coat
QW7 Bright White Clear Coat
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
SUA Tilt Steering Column
TBC Compact Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
TZH Michelin Brand Tires
WJN 15" Aluminum Wheels
WLZ All Aluminum Wheels
XBS Pickup Box
YAC Build To Canada Mkt. Specifications
YGA Without Billable Fuel
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z65 Left Front Group XIV
Z81 Right Front Spring Group X
Body Model JL61
Build date 10/28/90
  • 1 year later...
