captainkettel Posted December 11, 2012 Share Posted December 11, 2012 I have a 1986 XLS 4X4 with the 2.8L V-6. The clutch slave cylinder is leaking and needs to be replaced. I can get to the bottom bolt, But can not reach around the cylinder to get the top one. Do I need to drop or lower the transmission? Or I'm I just missing something? Anyone have any tricks or suggestions? Link to comment Share on other sites More sharing options...
MancheKid86 Posted December 11, 2012 Share Posted December 11, 2012 if you can't get the top one, put a jack under the transmission crossmember, lower the x-member once all the bolts are removed, youll have easier acess after that, try a bunch of extensions first, because the x-member bolts are usually seized to the frame Link to comment Share on other sites More sharing options...
Geonovast Posted December 11, 2012 Share Posted December 11, 2012 Wobble extension, u-joint, or shorty wrench may be your friend for this one. Link to comment Share on other sites More sharing options...
86FUBAR Posted December 12, 2012 Share Posted December 12, 2012 Ya I remember having the same problem ..... So I cut a hole in the floor and now it takes me 5 mins to change it out and I can bleed it by my self . I told myself that I was going to make a bitchin little sheet metal cover for it but that was like 12 or 13 years ago and the duck tape holds up real well ish... Link to comment Share on other sites More sharing options...
