flint54 Posted December 10, 2012 Share Posted December 10, 2012 Added an A/F meter to the dash panel just right of the cluster. Wanted the OEM clock also. Found said clock (actually several) at the JY and proceeded to methodically ruin each and every one of them. In this image you see the clock body, cut to receive the A/F meter. That hole required a minor trim of the circuit board. Note the three trimmed boards to the left. Although it looks drastic, that cut violated only one trace on the board. A jumper wire was carefully soldered to bypass the cut trace. The soldering was done by someone (not me) very well versed in miniature circuit board design and assembly, and then carefully checked for shorts and for continuity. Each board worked fine before the mod, and worked fine after the soldering, but failed after the trimming (by dremel). I can only surmise that the vibration caused a component failure (???). So, my fallback option shown here is to mount the meter in an original blank panel: But I really want a clock there also. Any suggestions? Link to comment Share on other sites More sharing options...
mvusse Posted December 11, 2012 Share Posted December 11, 2012 Is it possible they are dual layer PCBs? Link to comment Share on other sites More sharing options...
flint54 Posted December 11, 2012 Author Share Posted December 11, 2012 We looked very closely for that. Very simple circuit, very confident it's single layer only. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 11, 2012 Share Posted December 11, 2012 We looked very closely for that. Very simple circuit, very confident it's single layer only. It is. When I mounted a Benz ambient temp display in my 91 clock I had to Dremel quite a bit on the case - turned out the vibes killed the LED display. I had a spare, replaced the board/display, and it functioned again. http://comancheclub.com/topic/5323-mercedes-ambient-temperature-display-in-an-mj/page__hl__ambient For the A/F meter, I mounted it in an Autometer A-pillar gauge pod. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted December 12, 2012 Share Posted December 12, 2012 Don't you have a clock on your radio?? I put a trans temp gauge in that spot but I eliminated the clock because I have one on my radio. I removed the clock altogether and used some plexiglas to mount the gauge. It took a couple tries to get it done but I finally got it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted December 15, 2012 Share Posted December 15, 2012 HERE'S an option. Link to comment Share on other sites More sharing options...
flint54 Posted December 15, 2012 Author Share Posted December 15, 2012 Cool! Wonder what I would do with all those switches? Link to comment Share on other sites More sharing options...
fiatslug87 Posted December 15, 2012 Share Posted December 15, 2012 Link to comment Share on other sites More sharing options...
flint54 Posted December 15, 2012 Author Share Posted December 15, 2012 Well, the only thing that comes to mind is a brakelight kill switch, for running through the woods with minimum lights. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted December 17, 2012 Share Posted December 17, 2012 Well, the only thing that comes to mind is a brakelight kill switch, for running through the woods with minimum lights. Yeah, like that...when you're smuggling bootleg rum or some kind of powdery substance. But seriously folks, one is for driving lights, the other is for my aux e-fan. Pretty simple. Link to comment Share on other sites More sharing options...
