dirty88comanche Posted March 7, 2007 Share Posted March 7, 2007 about a week ago i fishtailed in the snow and hit a telephone pole. nothing to serious replaced the radiator and she runs again. now my question is what year xj's can i use to replace the bumber and grille and front end body panels as well as my driver side door. i have an 88 laredo package. thank you for your help. Link to comment Share on other sites More sharing options...
JOMJ87 Posted March 7, 2007 Share Posted March 7, 2007 you could go with 97+ and make the front look new or go with older and have it look the same and as far as doors go I am not sure which year but i know that some have a diff latch system that can be made to work with yours. Cole Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 7, 2007 Share Posted March 7, 2007 the 97+ are the only ones with different latch systems. anything from 84 through 96 will work on your truck. even the hood as long as it's from a cherokee with the same engine as yours. get a door from a similar year if you have power options as you'll want that to be the same (they're not too different if at all but best be safe). Link to comment Share on other sites More sharing options...
87manche Posted March 7, 2007 Share Posted March 7, 2007 the 97+ are the only ones with different latch systems. anything from 84 through 96 will work on your truck. even the hood as long as it's from a cherokee with the same engine as yours. get a door from a similar year if you have power options as you'll want that to be the same (they're not too different if at all but best be safe). not true, the 84's thru 86's have a different hood and radiator support. You need an 87-96 to steal body parts off of. In 87 they moved the hood latched from the center, to the corners, to make room for the 4.0's rad. Link to comment Share on other sites More sharing options...
jbhill Posted March 7, 2007 Share Posted March 7, 2007 hmm so the 84-86 XJs have a center hood latch? so i could replace the dual goofy crap that don't work on mine w/ a single one hmmm. Link to comment Share on other sites More sharing options...
87manche Posted March 7, 2007 Share Posted March 7, 2007 yes, you'll need the rad support as well, well, you might not ;) Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 7, 2007 Share Posted March 7, 2007 if you read closely, you'll notice i said as long as it has the same engine. they ARE the same through 88 on the 4 cylinders or through 86 on the v6 2.8. in 87 they changed to the 4.0 6 cylinder and THEN the hood and radiator support changed. jbhill, you'd have to do alot of custom work to make the center latch work...it would be easier to stick with the outer ones probably. either that or you will have to change the outer supports, as the earlier style radiators were narrower...and therefor had a narrower radiator support. Link to comment Share on other sites More sharing options...
JOMJ87 Posted March 7, 2007 Share Posted March 7, 2007 Do like me and put hood pins on it. Sorry to get off topic Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 7, 2007 Share Posted March 7, 2007 that's actually probably the easiest way. but i think jb is looking for the sleek look of a lowrider... Link to comment Share on other sites More sharing options...
87manche Posted March 7, 2007 Share Posted March 7, 2007 You may be correct then, I didn't see that in your post. I was under the impression that the core support changed for all modles in 87, regardless of motor. With the amount of work JB has already put into that thing I don't think changing the hood latch will pose a problem for him. Link to comment Share on other sites More sharing options...
ekulrenlig Posted March 7, 2007 Share Posted March 7, 2007 Someone correct me if I'm wrong, but you'll have to get a door from a 4-door cherokee. Link to comment Share on other sites More sharing options...
Oizarod115 Posted March 8, 2007 Share Posted March 8, 2007 Someone correct me if I'm wrong, but you'll have to get a door from a 4-door cherokee. yeah 2-door doors are WAY huge. 4 door XJ and MJ doors are the same Link to comment Share on other sites More sharing options...
