fiatslug87 Posted December 1, 2012 Posted December 1, 2012 Where is the location of the temperature sensor that feeds the overhead console in an early '90s XJ? What does it look like? Pictures are greatly appreciated.
Automan2164 Posted December 1, 2012 Posted December 1, 2012 Behind the bumper/grille. This is a pic of it on my '97, but it's nearly identical on older XJ's. Rob
fiatslug87 Posted December 2, 2012 Author Posted December 2, 2012 Thanks Rob, now I just need to grab one at the JY and figure out how to wire the whole console.
Backdraft Posted December 2, 2012 Posted December 2, 2012 I did a kind of write up on it over on naxja about 10 years ago back when it was a decent website. It was for a renix console going in to my 1990 XJ. Give me a few and I'll see if I can drum up a link for you. Haven't been there in a while.
Automan2164 Posted December 2, 2012 Posted December 2, 2012 The old style console is stupid easy with a wiring diagram. You just need a few wires IIRC. Power, IGN, Ground, Sensor signal, door ajar... I put one in my '91 Elim back in the day. Just don't go searching for the OHC connector harness end in the MJ. I made the mistake of thinking it would be present like most other things, and ended up messing up the TCU diag connector because it worked, but the wires were wrong.. When I got to tech school and was told about the diag connector... It hit me like a sack of bricks. Rob
relyt120 Posted December 2, 2012 Posted December 2, 2012 Same exact sensor in grand Cherokees as well.
Backdraft Posted December 2, 2012 Posted December 2, 2012 Hey guys, I found a few good threads and diagrams over at JU about this. Some are for a 87-96 XJ and some are for a 97+. This is the main thread I used for info: http://jeepsunlimited.com/forums/sho...hreadid=331934 here's a few pics of a 91 FSM overhead console wiring diagrams: http://community.webshots.com/album/58951859rKpKDa And another thread: http://www.jeepsunlimited.com/forums...he ad+console And yet another thread: http://www.jeepsunlimited.com/forums...he ad+console And another thread (very good for 97+): http://www.jeepsunlimited.com/forums...he ad+console Anyway, If you want specific info about the 97+ go over to JU and PM jeepzz, I belive that guy has done two or three of those. For the 87-96 I can tell you that you will need the brackets to mount the console with and you don't have to worry about drilling any holes, if you keep the mount screws from the donor there are indentations above your headliner in the metal where these are to screw into. You will also have to cut your headliner out for these. if your afraid to, remember the rule to measure twice and cut once. And for the wiring, which for me was the beast, there are something like 10 different ones from a harness that plugs into the computer. The wires for the lights are on a 5 pin harness that also plugs into the computer. Keep in mind that if your harness plug shows different color wires as I have seen in other overhead consoles don't worry about them and look at those pics from site two. The locations of the wires in the plug is what is important. They may be a different color but they are for the same thing as what the FSM locations show. Light wires you don't have to worry about but the computer wires are as follows: 2 Black wires = Ground(I ran these to the body for grounding.) 2 Pink wires = 12V+ power from battery(I hooked them up to the 12V+(red) from the dome lite.) 1 White wire = 12V+ switched power(power from ignition, I ran this to the power to my non-working aftermarket power door locks.) 1 Violet/Light Green = Temp Sensor(I ran this from the computer to the front bumper.) 1 Black/Light Blue = Temp Sensor(I ran this from the computer to the front bumper.) 1 Yellow wire = Ground signal to the dome lights(I ran this to the ground(black) for the dome light. Contrary to popular belief the dome lights work by closing a circuit via the door pins and the door pins are located after the lights in the circuit series hence the reason the yellow wire be connected to the ground wire to the dome light.) The rest are for dimming of the lights, I found them to be more of a PITA and didnt care if the thing dimmed or not. As far as the rumor of the harness plugs being in the pass side kick panel, your guess is as good as mine. Personally I didnt have any wiring in place and had to run all of my own wires. Either way, these wires are for the harness for the 87-96 and are the ones needed to have the lights, temp, and compass functional. One thing to be aware of is that if you try to power the computer up while its out of the console and does not have the green tinted glass in front of the display, you will not see a thing as it needs the tinted glas to show any signs of display life.(Ask me how I know this one) If you really want the dimmer to work refer to the second URL I posted for pics of the FSM and save the pics to your hard drive so you can blow them up and read them as they were very helpful to me. Hopefully this is enuff info for yall, but if you have any other questions about it PM me and ill be glad to help. Maybe I should get a write up on this together and post it somewhere for everyone to see HTH Some of the wire colors may be different for the MJ, however I think it should work out.
fiatslug87 Posted December 2, 2012 Author Posted December 2, 2012 Thanks guys. Hey Backdraft, the JU links are not working for me, do they work for you?
Backdraft Posted December 2, 2012 Posted December 2, 2012 Hmmm. No sir. They're not working for me either.
