comanchebuilder21 Posted November 7, 2012 Share Posted November 7, 2012 My t case exploded out of the housing today for my 88 so I'm looking for a cheap perfectly working one. To get me by for couple months Link to comment Share on other sites More sharing options...
johnny quest Posted November 8, 2012 Share Posted November 8, 2012 ive got a pair of 21 spline input np231's, but theyre with me in Utah... Link to comment Share on other sites More sharing options...
Bhfear Posted December 31, 2012 Share Posted December 31, 2012 I have a 231 in a 93xj 4.0 auto, it works just fine, but I don't know about the spline count? do some research on that $80 you can pick up 61254 or I can ship Link to comment Share on other sites More sharing options...
jpnjim Posted December 31, 2012 Share Posted December 31, 2012 The blown up t case on your sig pic has the front output broken right off. That usually only happens from contact, like when the ft driveshaft is too long, or the slip joint is completely seized. Just want to make sure the next one doesn't blow up too. Link to comment Share on other sites More sharing options...
JFAComanche6 Posted January 16, 2013 Share Posted January 16, 2013 The blown up t case on your sig pic has the front output broken right off. That usually only happens from contact, like when the ft driveshaft is too long, or the slip joint is completely seized. Just want to make sure the next one doesn't blow up too. How could the driveshaft be too long? I had to cut the CV joint off my front ds because it was too long with the cv joint on it, so would that be a problem? My 4wd doesnt act weird or anything, only when I make a sharp turn the front end jumps around a little but I believe thats a normal 4wd thing... Link to comment Share on other sites More sharing options...
