just as the subject says....i am wondering which rear end to put into my comanche....WHICH IS BETTER
i have my stock dana 35 non-clip rear thats got 3.07 gears now but i have a set of 4.10 in my garage waiting to go in...
i also have a 8.25 already with 4.10 29spline and locker and set up for an MJ with the correct perches welded on
i don't plan on going any taller than 33" with 4.10
My MJ now has a 3.5" lift and 32" BFG A/T...i already have 4.10 and a locker for my dana 30 just need to decide on the rear.....THX
thats what i read somewhere i just couldn't remember where lol
now i just got to get off my butt and do the switch....the u-joint flange on the d35 and 8 1/4 use the same u-joint right??
The u-joint is the same, but the pinion snout on the 8.25 is about 5/8" longer than the D35 so you may have to shorten your driveshaft.
hey update...the axle the guy gave me is a total waste because its an open carrier, 3.73, and 27 spline so anyone have a 97 or newer one with 29 spline and 4.10????
BUMMER!!!
I have a 29 spline 8.25 from a XJ with a LS and 3:55 gears sitting in the garage....Just waiting for another project.... :brows: :brows: :brows:
CW
