Southpaw26 Posted November 4, 2012 Posted November 4, 2012 Well I pulled my carpet out today as advised by Pete M. What I found was not all so bad I do not think. I found less than eight small rust holes. All of them smaller than a dime and most smaller than a eraser on a pencil. I am thinking my best coarse of action here is to use a wire brush and then Ospho everything. From there I thought I would follow up with a treatment of POR15 or some Rustoleum rust bare metal primer. What do you guys think? Am I heading in the right direction? What would you use to cover the small rust holes? How does it look compared to most? Thanks Pete for the warning in your Sig.
ncmountainMJ Posted November 5, 2012 Posted November 5, 2012 lol naa your good! my first MJ had a hole the size of a fist right under the gas pedal where your heel would rest and all the seat bols broke off trying to remove the seat....
Southpaw26 Posted November 5, 2012 Author Posted November 5, 2012 I thought this looked pretty good. That is with no cleaning. It was pretty wet under there. The padding was wet for sure. Not really sure why. I am guessing just age and maybe a window left down at some points along the way. The PO had had someone to make a second carpet kit at some time and they literally just put it over the original. So there was two layers of carpet and the backing pad of course.
Keyav8r Posted November 5, 2012 Posted November 5, 2012 Your floors look almost production line perfect compared to what mine used to look like. I haven't used Por-15 but guys I know who have say you can just about lay newspaper over the holes and coat it to seal the floor. Newspaper may be an exaggeration, but I would think fiberglass cloth would work. You'll probably get several recommendations from forum members who swear by it.
Pete M Posted November 5, 2012 Posted November 5, 2012 The padding was wet for sure. Not really sure why. I am guessing just age and maybe a window left down at some points along the way. the more likely cause is a leak. Our trucks are prone to them and the cause could be ANYTHING that could possibly leak. from the firewall, to the windshield, to the door seals, to the rear window. find the leak before putting the carpet back. :thumbsup:
Dadinator Posted November 5, 2012 Posted November 5, 2012 Yep. Mine leaks at the windshield in 2 places. Whenever I get a job, I'll get a new windshield. I need a job.
Southpaw26 Posted November 6, 2012 Author Posted November 6, 2012 I am putting in a new windshield anyways. I think am going to go with the new style rubber windshield gasket. I was told it will go right in. So what should I use to fix the small pin holes?
Southpaw26 Posted November 7, 2012 Author Posted November 7, 2012 Anyone got any ideas or opinions on what to use to fix those small rust pin holes?
Pete M Posted November 7, 2012 Posted November 7, 2012 If you're going to por it, you can put tape underneath so the por lays flat, then remove tape once the topcoat is cured and you're ready for the underside. or hit it with a welder.
87Warrior Posted November 7, 2012 Posted November 7, 2012 If you're going to por it, you can put tape underneath so the por lays flat, then remove tape once the topcoat is cured and you're ready for the underside. With the small amount of rot through on your truck, this would probably be the easiest solution.
Southpaw26 Posted November 9, 2012 Author Posted November 9, 2012 The under side of my truck has been totally undercoated.
