90PioSport99 Posted March 2, 2007 Share Posted March 2, 2007 I'm just not sure what a couple of these wire ends are. I have pretty good ideas, just not 100%. We'll start off with my almost postives here... Hood light I have to assume. It's all just wound up in the relay center and has like 5 feet of excess. Another view...It comes out of the wiring loom that the blower motor wiring is in Next one I have to assume is the washer fluid level sensor plug? These last two I really have no intelligent ideas on. Maybe A/C Compressor on this one? Red wire with black tracer. All I can come up with for this one is fog lights. I have the switch inside that says fog lights but I haven't traced the wires and the thing doesn't have fog lights right now. I also couldn't find the relay for them which is strange if it really did have them. Maybe electric fan wiring too-maybe. Kind of a cool weatherpack plug block off, I've never seen one of those before. Any ideas on these would be great. Not really worried about them, just curious. Thanks guys, Collin Link to comment Share on other sites More sharing options...
Eagle Posted March 3, 2007 Share Posted March 3, 2007 My '88 MJ apparently had factory foglights. The switch is on the dashboard. It had no lights when I bought it and I haven't traced the wiring, but there is a relay on the driver's side radiator side brace that doesn't exist on my '88 XJ, so I believe that's where the foglight relay should be. Link to comment Share on other sites More sharing options...
90PioSport99 Posted March 3, 2007 Author Share Posted March 3, 2007 My '88 MJ apparently had factory foglights. The switch is on the dashboard. It had no lights when I bought it and I haven't traced the wiring, but there is a relay on the driver's side radiator side brace that doesn't exist on my '88 XJ, so I believe that's where the foglight relay should be. Yeah I wonder about that. It's a Pioneer so it was available and the weird thing was the switch was just mounted in that "blank" in the dash bezel, it wasn't in it's own switch panel. I don't know for sure though, I'm going to try to trace wires. Anyone else have ideas on the rest? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted March 4, 2007 Share Posted March 4, 2007 if that switch was in the bezel blank, it's either not original or the bezel isn't original. but no one is dumb enough to cut out the bezel so i'd say aftermarket...but it may be that someone pulled the fog system from another mj or xj and just laid it in... Link to comment Share on other sites More sharing options...
90PioSport99 Posted March 4, 2007 Author Share Posted March 4, 2007 if that switch was in the bezel blank, it's either not original or the bezel isn't original. but no one is dumb enough to cut out the bezel so i'd say aftermarket...but it may be that someone pulled the fog system from another mj or xj and just laid it in... I don't know though, the thing is, it was a factory switch in the dash bezel blank area. That was the weird part. Anyway that thing is gone now and I have the true switch panel mounted there. There is the green wiring right behind that area that has a label that still says fog lights on it. I'm just trying to figure if that weatherpack connector in the engine bay is for fogs or what? I'm starting to think it is. Link to comment Share on other sites More sharing options...
Pete M Posted March 4, 2007 Share Posted March 4, 2007 Can you flip the switch and check for power? Link to comment Share on other sites More sharing options...
90PioSport99 Posted March 4, 2007 Author Share Posted March 4, 2007 Can you flip the switch and check for power? Well I guess I could plug the plugs into the back of the switch. I just can't seem to even see where those wires would go though, and the partial harness definitely didn't make it to the front end anywhere. Link to comment Share on other sites More sharing options...
