ComancheKid45 Posted October 21, 2012 Share Posted October 21, 2012 Installing an upgraded booster in my 88 2wd MJ. The booster came out of a 2000 XJ. Plumbed all the lines and such and when i went to bolt up the petal I noticed it sat WAY higher than it did before! I have the metal spacer behind the foam on the booster but added some custom spacers to help drop it back a bit, it has helped some but its still at a decent height. Are there an issues I'm not aware of or is this just a by product of this model booster? I have a duel booster out of a 96 XJ in my Blue 88 and it acctually made the pedal sit a bit lower. Thanks for any advice! Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 21, 2012 Share Posted October 21, 2012 It has to be specific to the 2000 booster arm length. Did you compare the old single diaphragm booster to the new one before bolting it in? Link to comment Share on other sites More sharing options...
Exgrayxj Posted October 26, 2012 Share Posted October 26, 2012 Just did this on my xj, used a 99 xj booster/master. The pushrod is indeed longer. If forced to use the existing hole on the brake pedal it put the pushrod in a bind on the edge of the booster neck. And made the pedal high. I eyeballed where I thought it needed to be (I think about 1 1/2" lower) and drilled a new hole for the pushrod bolt. If I was to do it again (and I probably will, on the mj) I will probably get the later pedal, and save drilling the pushrod and pedal. BTW, I got a Chevy brakelight switch, and used the existing bracket to mount it, did away with the funky Ford style one. Great to have brakes. Edit: While I had the pedal out, I cut 1 1/2" from the right side of the steel pad, following the same angle, then trimmed the pad the same amount between the ribs, the little rib on the backside needs a little trimming also, and glued it in place with some "liquid nails" (don't laugh, it's what I had handy), put a zip tie around it to hold it in place while it dried, this gave me some more foot room, my right foot thanks me daily and I no longer am hitting the brake/throttle at the same time. I don't have to C#*@ my foot to the tunnel now. Link to comment Share on other sites More sharing options...
