Sugarfoot Posted October 14, 2012 Posted October 14, 2012 Is it possible to pull the trans back far enough on an 88 4.0 BA 10 trans with 4x4 to replace the trowout bearing or do I have to drop it compeletly? If so what is the shortest route to do this?
Comanche County Posted October 15, 2012 Posted October 15, 2012 Just drop the transmission and the TC, it doesn't take that long. You'll need everything out of the way to do the throwout bearing. You'll need to inspect the inside of the bellhousing anyway. Plus, while you're in there you should go ahead and replace everything, clutch, PP, and the PILOT BEARING! Sometimes the pilot bearing can be a bugger to get out. Some pilot bearing pullers won't do the job and you'll have to drill a small hole in it, then chisel and break it into pieces to completely remove it. No easy way to wiggle it in there, just drop everything and replace with new parts. You'll thank yourself later.
Eagle Posted October 15, 2012 Posted October 15, 2012 You asked this two days ago and it was answered. http://comancheclub.com/topic/32175-bearing-in-ba10-making-noise/
