Zenobian_84 Posted October 14, 2012 Posted October 14, 2012 Decided to get another valve cover gasket. To no surprise, the cork is finally giving up the ghost again; plus, I'm giving the truck a tune up anyway, so it was time for another. Found this nice (but pricey) gasket on Advance Auto's listing under a '98 2.5 Dakota (PN: VS 50502 R). Looks like the same one I have on my oil pan (also found under a '98 2.5 Dakota) and like one's I've seen for the 4.0s. I know about the "Crush Spacers" on the 2.5 aluminum valve cover, but am unsure if the Dakota uses the same style on the newer 2.5s. Has anybody tried using this gasket on a Renix 2.5? If not, I might just pony up the money to give it a test; either that, or take in my spare aluminum valve cover to see if they can let me test it out. :dunno:
87Warrior Posted October 14, 2012 Posted October 14, 2012 Subscribing to follow this. I have been collecting parts to do the aluminum valve cover swap but refuse to use one of the dang cork gaskets.
Zenobian_84 Posted October 16, 2012 Author Posted October 16, 2012 Rejoice my 2.5 brethren; finally found a solution for those of us who hate using those $#!&ty cork gaskets. Went and picked up the 98 2.5 gasket I posted earlier about. $28 later. Fits like a glove, and is the same quality as the one piece one I picked up for the oil pan earlier this year. This one will only fit the aluminum valve cover, so you guys still running the plastic are stuck with the cork / rubber combos. One more potential oil leak I can eliminate for good now. Hopefully this will be the last pricey purchase; trying to cut back on $ spending for a while... :ack:
87Warrior Posted October 16, 2012 Posted October 16, 2012 B-E-A-U-T-iful Looks like I will be ordering one.
87Chief Posted October 16, 2012 Posted October 16, 2012 Whats the part number for the oil pan gasket? Same 98 2.5 Dakota? I need to do my pan gasket AGAIN want a one piece
Zenobian_84 Posted October 16, 2012 Author Posted October 16, 2012 OS 34007 R - 1 Piece oil pan gasket From the description and pictures of it on the website, it looks nothing like the one I bought previously. In fact, I can't find that particular gasket anymore at all! :fs1: My advice is to buy at least 2 of those nice valve cover gaskets and hope they don't discontinue them like I'm assuming they did with the nicer oil pan ones.
