Slave Cylinder Replacement
Leaking from bellhousing, ax15,4.0 1990
Do i need to drop the transmission? Off road only, I don't plan on putting more than 5000 miles on the truck. Is there a write up of this? ( sorry my phone is my computer) thanks!
  • 3 months later...
The BA10 had phased out by '89. So, if it is original, it is most likely an AX-15.
A way to verify it is to look at the trans. If the case is split vertically, left and right halves, then it is a BA10.
If it split horizontally, top and bottom halves, then if it is an AX 15.
