jimoshel Posted October 2, 2012 Share Posted October 2, 2012 There was a set of front ( I assume ) coil springs in the bed of a MJ I just drug home. I think they are for a MJ-XJ. I don't have a loose one out I can compare them with. There is a tag on one of them It has the letters, large, JG 3 times. 2 rows of smaller letters first letter indistinct ?208 2nd row 9143 Can anyone here identify them? Also there was a D44 axle assembly, judging by the spring mounts for a MJ. missing the right hand axle shaft. Are the D44-D35 axle shafts interchangeable? Any input appreciated. Link to comment Share on other sites More sharing options...
HOrnbrod Posted October 2, 2012 Share Posted October 2, 2012 This might help: MJ Coil Spring Codes 5200 1107 AR MJ Light Duty, Coded EF (#655) 5200 1108 AR MJ Light Duty, Coded EG (#690) 5200 1109 AR MJ Light Duty, Coded EH (#727) 5200 1110 AR MJ Light Duty, Coded EJ (#765) 5200 1111 AR MJ Light Duty, Coded EK (#806) 5200 1784 AR MJ Light Duty, Coded EL 5200 1785 AR MJ Light Duty, Coded EM 5200 1786 AR MJ Light Duty, Coded EN 5200 1787 AR MJ Light Duty, Coded EP 5200 1788 AR MJ Light Duty, Coded ER 5200 1789 AR Standard Duty, Coded FL 5200 1114 AR Std. Duty, Coded FE (#607) 5200 1115 AR Std. Duty, Coded FF (#646) 5200 1116 AR Std. Duty, Coded FG (#688) 5200 1117 AR Std. Duty, Coded FH (#733) 5200 1118 AR Std. Duty, Coded FJ (#780) 5200 1119 AR Std. Duty, Coded FK (#831) 5200 1790 AR Std. Duty, Coded FM 5200 1791 AR Std. Duty, Coded FN 5200 1792 AR Std. Duty, Coded FP 5200 1120 AR H.D., Coded GD (#578) 5200 1122 AR H.D., Coded GF (#670) 5200 1121 AR H.D., Coded GE (#622) 5200 1123 AR H.D., Coded GG (#720) 5200 1124 AR H.D., Coded GH (#775) 5200 1125 AR H.D., Coded GJ (#834) 5200 1793 AR H.D., Coded GK 5200 1794 AR H.D., Coded GL 5200 1795 AR H.D., Coded GM 5200 1796 AR H.D., Coded GN D35 & D44 axles not interchangable. D44 is thicker with different spline counts and length. Link to comment Share on other sites More sharing options...
jimoshel Posted October 2, 2012 Author Share Posted October 2, 2012 Not what I wanted to hear but exactly what I expected. So now the search is on for a axle shaft. Tnx Don. Link to comment Share on other sites More sharing options...
Eagle Posted October 2, 2012 Share Posted October 2, 2012 D44 and D35 axle shafts are not the same, but a D44 from an XJ will have the same shafts as a D44 from an MJ. Link to comment Share on other sites More sharing options...
mnkyboy Posted October 2, 2012 Share Posted October 2, 2012 Keep in mind that D44 shafts are different lengths from side to side,the passenger side is longer but in a pinch a driver side shaft will fit the passenger side. Also TJ D44 shafts will fit the MJ/XJ D44 and are usually easier to find. Link to comment Share on other sites More sharing options...
