Trans And Tcase?
Got me a 1987 mj with the 4.0. Thinking of buying a stroker, or getting my engine built locally. Looks like I may have a complete spare truck as well.
Anyway, should I go for a different auto tranny and newer tcase right from the get go? Thinking about the issues with 21 spline tcase input on the 87 tcase with the aw4 tranny, and the reliability in general of the stock trans.
What transmission should I go with?
Sorry but the search function just is not working tonight on the forum
The AW-4 should be able to handle a stroker just fine. You drivetrain concern should be with your rear axle.
I've been on this forum for over 5 years, and I haven't seen a single post about someone snapping a 21 spline trans output shaft/ t-case input.
I have an 87 MJ with the Renix 4.0, AW4 transmission with the 21 spline output and 35" tires on locked axles. Been told I wheel my truck harder than most, but have never had an issue with the transmission or transfer case. For that measure, never had an issue with the 4.0 either, and I like the simplicity of the Renix electronics. From my experience way more reliable than the Chrysler system used on the HO engines.
Thanks for the replies! I am sticking with the renix, and apparently the tranny issues I heard about were all regarding the manual trannys. Got a complete spare truck too! I just have to go get it. Gonna build it as is. Now I just have to sell this 2006 rubicon unlimited and I can start in on it
  • 4 months later...
