AMCJeepMJ Posted September 22, 2012 Share Posted September 22, 2012 Picked up a fresh set of Moog end links for the sway bar, and after researching online I am unable to find any torque specs. This is for both where it connects to the axle and for the bushings connecting to the sway bar. In the event of no torque specs, is it a case of 'torque it til it feels snug', or is it 'crank those bad boys down'? Thanks! Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 22, 2012 Share Posted September 22, 2012 I've always just snugged them up until they squish down maybe 25% or so. Whether this is correct or not :dunno: . Link to comment Share on other sites More sharing options...
skidoo_j Posted September 22, 2012 Share Posted September 22, 2012 Stabilizer bar to link bolt 45ftlbs stb ar frame bracket 30 ftlbs stablizer bar link to suspension bracket 45 ftlbs pages 907-909 in the 90fsm.pdf what years are you looking for? 90 http://www.greatlake.../tech/90fsm.pdf 88 http://www.greatlake.../tech/88fsm.zip http://www.greatlake.../tech/93fsm.zip http://www.greatlake.../tech/94fsm.zip the one for the 01 file name is 01_XJ_FSM.? but i'm not sure if that's correct as i couldnt' find it again... his tech page and the links are all down but it seems most of the files are still on his server so www.greatelakes.com/tech/.... 97XJ.pdf parts catalogs: 1988-1990_parts_catalog.pdf 1991-1993_parts_catalog.pdf 2001_parts_catalog.pdf 1997-1999_parts_catalog.pdf Renix_Fuel_Injection_Manual.pdf Link to comment Share on other sites More sharing options...
AMCJeepMJ Posted September 23, 2012 Author Share Posted September 23, 2012 Awesome, thank you. It worked like a charm! Link to comment Share on other sites More sharing options...
