jeepsouth Posted September 22, 2012 Share Posted September 22, 2012 dist. wobbles ,and oil leaking. New dist. needed? Link to comment Share on other sites More sharing options...
cruiser54 Posted September 22, 2012 Share Posted September 22, 2012 Probably. Have you replaced your oil pump lately or had the dizzy out for any reason? Link to comment Share on other sites More sharing options...
jeepsouth Posted September 22, 2012 Author Share Posted September 22, 2012 No just trying to determine where the oil drops on my driveway are coming from. Saw the dist. moving ,and oil trail from base of it. Link to comment Share on other sites More sharing options...
HOrnbrod Posted September 22, 2012 Share Posted September 22, 2012 The distributor has a seal (p/n 33004595) and gasket (p/n J3181288) inside on the body shaft where it fits in the engine hole. If it's missing it will leak oil and move from side to side if the distributor clamp collar isn't secure. So pull it out and check first. Link to comment Share on other sites More sharing options...
jeepsouth Posted September 22, 2012 Author Share Posted September 22, 2012 Thanks Don, I'll check it out. Link to comment Share on other sites More sharing options...
cruiser54 Posted September 22, 2012 Share Posted September 22, 2012 But the distributor shouldn't be wobbling. Check the play in it when you have it out. Link to comment Share on other sites More sharing options...
