Kenosha Warrior Posted February 25, 2007 Share Posted February 25, 2007 Overnight it leaked about a spoonfull. It just started happening, just went out and looked at it and the lower rad hose is dribbling, right where it connects to the block. Yipee. Probably going to have to do the thermostat too while I'm at it. Link to comment Share on other sites More sharing options...
carnuck Posted February 26, 2007 Share Posted February 26, 2007 More likely the waterpump than the hose. Could be a loose clamp though (mine snapped while driving!) Link to comment Share on other sites More sharing options...
Pete M Posted February 27, 2007 Share Posted February 27, 2007 If I remember right I've 3 different leaks there. One from a cracked hose at the pump, one from a not-tightened-enough clamp at the pump, and 2 from leaking water pumps. Link to comment Share on other sites More sharing options...
