SwayAwayComanche Posted September 7, 2012 Posted September 7, 2012 Hey guys,I'm about to do a leaf over on my 88. what pinion angle would be desired? sorry for the double post, posted on my phone.
skidoo_j Posted September 7, 2012 Posted September 7, 2012 If you're going to convert your transfer to a SYE you want the driveline to pinion to be as close to 0 as possible. If you're leaving the factory slip yoke you want your pinion to be parallel to your transfer case output. http://www.4crawler.com/4x4/CheapTricks ... -101.shtml http://www.4x4wire.com/toyota/tech/driveline/ You should be able to delete the second post when on a computer.
