I am getting ready to install a Chrysler 8.25 rear end. I have some questions about measurement and perch placement. I know that the pinion angle needs to be correct. Would -2 degrees be about right? What other measurements do I need to take into consideration besides pinion angle?
  • 4 weeks later...
Spring pads need to be moved inboard 1.5" per side and shock mounts added. Pinion angle should be flat unless you have a slip yoke eliminator
Pinion angle depends on the type of drive shaft used. If it has single u joints on both ends, it should be parallel with the transfer case output, or ~2 degrees below so it will be parallel under load going down the road. If going SOA, shock mounts on the axle instead of using the stock ones on the u bolt plates are a good idea.
Either way (SOA or SUA) perches will need to be cut off and new ones welded on in the correct position.
