DubbyDoo Posted August 11, 2012 Posted August 11, 2012 is it normal that this controls the power to the radio as well ? I have a radio fuse but when I pull the dome fuse it cuts power to the radio
skidoo_j Posted August 11, 2012 Posted August 11, 2012 IIRC the dome fuse is the constant power to the radio. and the radio fuse is the ACC power to the radio. Which is funny because most of the power draw on a radio is on the constant power side. Atleast this is how mine was when I faced the same issue as you currently and I traced all the wires from the radio trying to figure out what the PO had screwed up now, but I found no splices that were not factory.
cruiser54 Posted August 11, 2012 Posted August 11, 2012 Maybe this will help. http://snowboard247.blogspot.com/2005/0 ... -info.html
