trailering
RynoMJ
yea itll fit on a reg. trailer. here's mine on an 18 foot car trailer. its closer on the left side then the right so yea.
So i see the lowrider will be RHD. where did you come up with the dash and firewall for that? or are you custom making it? i've been wanting to convert my MJ to RHD if i could ever find a 97 plus RHD cherokee for a donor...
haha yea i tow w/ it sometimes. its rated at towin 5600 lbs so i figured ynot. o and trailer brakes are my friend lol.
i got the dash from
http://www.discountjeepparts.com/index. ... /3121_3128
and the instruement cluster bezel from
http://www.teamgrandwagoneer.com/cgi-bi ... hand+drive
i didnt get the cluster cuz it was HELLA expensive, plus all i needed was the shell anyways. i still gota get the lower part of the dash(gona try to mod the LHD stuff to work) but the dash i got was new in the box so i can't complain.
yea my ranger has 4:10 gears and trac loc front and rear :D o and a an 8.8 w/ 31 spline axles :D
here's the dash pic
:bowdown:
OK that settles it, I'm doing that conversion on at least 1 mj. just emailed on the dash, but i wish they didn't just have woodgrain bezels. They're checking on a black one for me before I order it :D
i wanted the wood grain so i can paint it body color :D its smooth so all i got do is wetsand it and paint it!
ah, good point. I would just paint it black myself. but that's just me. so where are the footwells gonna be on that thing? isn't the frame gonna run right through them?
na its all gona be hand made, the floor will only be a bout 3 in higher then stockw/ a really small tranny tunnel.
that's not too bad. I knew you were making it yourself, just wasn't sure how you were gonna go about getting a foot well in the thing. i thought the frame would be in the way.
by the way, how low to the ground is it going to be? the pics showed it literally resting on the ground...how is that gonna work? air bags?
