Zenobian_84 Posted August 5, 2012 Share Posted August 5, 2012 Went out of my way a few days ago out to the CarQuest where my GF works at to bring her some breakfast, and buy a few parts from her store. Bought this little sucker with the intent to replace my crappy one on the passenger side of the cab that only works 25% of the time. Problem with the new one is that it isn't a single spade like the old one; it's a plastic wedge piece. Removed the old one, and left the wiring sitting out of the hole enough to grab it with a pair of needlenose, and just as luck would have it, it got bumped into back into the depths of the inside of the cab. What exactly do I need to remove to gain access to be able to run it though the proper hole and screw in a new DJS? Also, anybody got a lead on a new DJS? The one from CQ doesn't fit at all; Exact fitting my @$$. :shake: Hopefully it wasn't one of those rare, "AMC ONLY" dealer parts I hear about from time to time. :ack: :roll: I'm making a P&P run with a buddy of mine Tuesday morning to Orlando and Daytona Beach; and there's at least 10 Cherokees in each I can pull at least 4 out of. Inquiring minds want to know in case of premature failure of the junk ones... :yes: Link to comment Share on other sites More sharing options...
jimoshel Posted August 5, 2012 Share Posted August 5, 2012 * happens. If you can find a metal coat hanger straighten it out and put a small hook on one end. Works pretty good at fishing loose wires out of dark holes. :wrench: Link to comment Share on other sites More sharing options...
Harley Posted August 5, 2012 Share Posted August 5, 2012 I supose ya could remove that kick panel, drill a hole and snag it that way too. that might also help ya with feeding to where it belongs. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted August 6, 2012 Share Posted August 6, 2012 I bought mine new at the dealer. They still had them listed when I bought it, maybe 5 years ago. fit perfectly and has worked great ever since. Link to comment Share on other sites More sharing options...
