COFFMAN Posted July 30, 2012 Share Posted July 30, 2012 Has anyone done this fitted XJ tail lights into a MJ Had a quick look last time i was home and i would think it would be doable Any imput would be great Link to comment Share on other sites More sharing options...
mvusse Posted July 30, 2012 Share Posted July 30, 2012 Considering the size is completely different and the wiring won't support separate turn signal and brake lights, it would mean major fabricating for them to fit and work. Link to comment Share on other sites More sharing options...
Pete M Posted July 30, 2012 Share Posted July 30, 2012 yup. it's been done (I remember seeing a latemodel XJ conversion done with taillights included), but you'll need some good steel fabbin' skills to make it look factory. Link to comment Share on other sites More sharing options...
COFFMAN Posted July 31, 2012 Author Share Posted July 31, 2012 Did a search and found a black mj with 97+ tail lights Looked good Will go into more detail when home next in fitting these to mine By law in OZ indercators lights must be amber so its the +97 option or plate the hole a fit sealed beam type which also looks good :wavey: Link to comment Share on other sites More sharing options...
1990 Pioneer 4x4 Posted July 31, 2012 Share Posted July 31, 2012 no, but i fitted XJ covers to somewhat fit my MJ :D Â Link to comment Share on other sites More sharing options...
mvusse Posted July 31, 2012 Share Posted July 31, 2012 Did a search and found a black mj with 97+ tail lights Looked goodWill go into more detail when home next in fitting these to mine By law in OZ indercators lights must be amber so its the +97 option or plate the hole a fit sealed beam type which also looks good :wavey: Â Common solution in Europe I believe is to use an amber bulb in the backup light socket and use that for the turn signal, and then use aftermarket backup lights fitted inside the bumper. Link to comment Share on other sites More sharing options...
