XJ Tail Lights Into MJ
COFFMAN
Did a search and found a black mj with 97+ tail lights Looked good
Will go into more detail when home next in fitting these to mine
By law in OZ indercators lights must be amber
so its the +97 option or plate the hole a fit sealed beam type which also looks good :wavey:
Common solution in Europe I believe is to use an amber bulb in the backup light socket and use that for the turn signal, and then use aftermarket backup lights fitted inside the bumper.
