lexluthier72 Posted July 22, 2012 Share Posted July 22, 2012 Hey folks, A very gracious friend has offered to help weld in my floors (while I am recovering from a pinched nerve) My question is, I assume you have to drop the fuel line? I have not had a close look at how they come down from the side of the truck. Any info would be great. -Erin Link to comment Share on other sites More sharing options...
1987Comanche Posted July 22, 2012 Share Posted July 22, 2012 The fuel line is fairly close to the floor on the driver's side. I purchase a "Velvet shield" welding blanket that's rated to protect nearly anything and it did a good job when I put floors in the '87. I use it to wrap fuel tanks when welding exhaust systems anywhere in the vicinity of one. Granted I try to keep the welder as far away from fuel containing objects as possible but, in certain circumstances (the last weld when the exhaust system is in place) there is little choice. Link to comment Share on other sites More sharing options...
lexluthier72 Posted July 22, 2012 Author Share Posted July 22, 2012 Thanks! I'll look one up. In the meantime, are there clips that hold the line up? I have heard most folks just drop them out of the way Link to comment Share on other sites More sharing options...
sinkrun Posted July 22, 2012 Share Posted July 22, 2012 I used a pre bent pan and it can up the side of the centre hump about 3" above the fuel line (XJ) so we just kept a eye on how close we were. I think we may have even used a wood block to push it away from the body. Link to comment Share on other sites More sharing options...
lexluthier72 Posted July 22, 2012 Author Share Posted July 22, 2012 Ok...cool. I'll have a crawl under there when it is not 100 degrees out and see what I'm really up against. -E. Link to comment Share on other sites More sharing options...
87Warrior Posted July 22, 2012 Share Posted July 22, 2012 The fuel lines are held into place with plastic clips that also hold the rear brake lines. Pry all of the clips off the truck and move the lines away from the welding area. I had a buddy offer to weld in ly floors. Once they were in, I think he regretted the offer as it was far more work than he imagined. He was compensated well. Link to comment Share on other sites More sharing options...
