WTB 120mph Speedo
flint54
Here's a 200KPH (124.2742 MPH) NOS speedo that will work - I've been thinking about it. CLICK
You can also get them from the UK as the 91+ XJs all got 120 MPH speedos. But because they are RHD there's a couple of jumper wires you have to wire in on the back foil but it's easy to do.
Don,
Where was that one available and when?
I have a calibrated 120 mph speedometer with 3 gauges and the big fuel Is that what you are looking for?
No, that's the police package cluster. This is the one I like:
Well, the "200" would sure be interesting, even if in K/ph. It would keep
my feeble brain active continuously converting speeds. The downside is
that the odometer probably also reads in kilometers rather than miles.
I am assuming, perhaps wrongly, that the speedo can be readily swapped
between clusters, since I'm more likely to find the police cluster than the one
Don shows in the image. When I bought my MJ the trip meter was in-op and
I swapped in a (same part number) speedo after having the mileage set
to match by a gauge shop. Not sure if there are other differences in cluster
or sender that could affect the ability to swap in alternate gauges.
Johnj92131, are you saying you have one for sale, or one in your truck?
Don, do you keep rare Jeep parts lying around your kitchen just for decor?
Yep. Learned it from Rob. :yes:
This is the 91 and up cluster w. the police speedo inserted. Plug and play. But it needs new gauge faces to make them match. The police speedo never came with the full 6-guage cluster.
The other pic I posted above is the UK cluster found in all their 91 and up XJs until the dash change.
