Manual for Auto swap info
The best info will be a factory service manual.
You will need the tranny, the tranny computer, the tranny mount (the cross member is the same, but the mount is different), and the tranny shift linkage. If you have an AX-15 you should have a 23-spline output, so your transfer case should bolt up to most AW4s unless you get a very early one.
Obviously, you'll need a flex plate (flywheel). Be sure you get the right one for your year electronics. The ones from the Chrysler years won't trigger the Renix CPS properly, and vice versa.
I'm not certain, but I believe you'll have to adjust the length of your rear drive shaft.
Dang. I'll have a rolling parts MJ ('89 2WD) complete with 4 speed as soon as my son and I get the motor, radiator, and alarm system out of it. I'll just want it to disappear ($0). But there is the small problem of a continent between us.
