jimoshel Posted July 6, 2012 Share Posted July 6, 2012 Interesting problem almost opposite to what Minuit posted on his truck cutting out. 1994 XJ. 4.0, auto.The first 2 or 3 times turning the key to start, the engine turns over but doesn't fire. After several tries it fires but dies immediately. This happens several times. After doing this a half dozen times the engine will run for 1 or 2 seconds and die. This goes on half a dozen times, each time the engine runs for a second longer. Keep the foot off the gas. Pushing the gas pedal kills it instantly. After 5-10 minutes of this I can finally give it some gas. It revs up good. Taking it out on the road it runs good, shifts thru all gears good, hits 85mph, was still winding out but I backed off, holds a steady 75-80 with no miss. Once it's warmed up there is no problem. Always starts and runs first try. Just does it when cold or been sitting awhile. Throws codes 12, 24, 14, and 55. Swapped the tps, the IAC and the MAP with another XJ. The trouble stayed with the original engine. The second Jeep ran good with these parts. Getting the proper voltage at the plugs, +5VDC. When I got the Jeep home I found 1 used and 2 new CPS on the floor, and looks like a new one on the engine. Apparently the PO tried to fix it himself, with no luck, which is why he sold it. Any and all ideas solicited and welcome. :dunno: Link to comment Share on other sites More sharing options...
Geonovast Posted July 6, 2012 Share Posted July 6, 2012 Do you have a different ECU you can try? Link to comment Share on other sites More sharing options...
HOrnbrod Posted July 6, 2012 Share Posted July 6, 2012 Remember this post Jim? http://www.comancheclub.com/forums/viewtopic.php?f=2&t=21043&p=216280&hilit=asd+relay#p216280 Might be a sticking ASD relay, or it's not getting it's latch signal from the distributor and preventing starting when cold. Link to comment Share on other sites More sharing options...
jimoshel Posted July 6, 2012 Author Share Posted July 6, 2012 HA!! Completely forgot that one. Gonna go try it. They say the memory is the second thing to go. Don't remember what was first. Link to comment Share on other sites More sharing options...
jimoshel Posted July 6, 2012 Author Share Posted July 6, 2012 Should have stated in the first post. At the fuel rail, 25psi switch on, engine not running, 22-23psi with engine running. These numbers are not correct. The pressure is 35 PSI. Not sure if that error was due to a typo or a brain fart. Link to comment Share on other sites More sharing options...
Stacks Posted July 6, 2012 Share Posted July 6, 2012 Jim... isn't that fuel pressure about half of what it should be? I'm basing that comment on my '97 TJ pressures. It runs 44-46 psi at an idle and about 42-44 key on but not running. I believe the FI is basically the same for your '94 and my '97. The ASD sounds more likely. The low fuel pressure may be a different issue. Just a thought to ponder. Later, Larry Link to comment Share on other sites More sharing options...
