Virginia Posted July 2, 2012 Share Posted July 2, 2012 It's that knocking sound when I accelerate. I call it lifter rattle. Not sure what it really is. It gets faster as the engine revs but stops when I'm sitting still. The oil is good. The pressure is good. Oil pressure is about 40 at 65mph. I ideas? Link to comment Share on other sites More sharing options...
Garvin Posted July 2, 2012 Share Posted July 2, 2012 If it's coming from the top of the engine then it's probably a collapsed lifter. If you take off the valve cover and tap the engine until the valve is completely closed then you should be able to wiggle one to see which one of the twelve is the culprit. Link to comment Share on other sites More sharing options...
Virginia Posted July 2, 2012 Author Share Posted July 2, 2012 And then? Link to comment Share on other sites More sharing options...
Garvin Posted July 2, 2012 Share Posted July 2, 2012 You can try putting in oil stabilizer or Mystery Oil to see if it will pump the lifter up. If it doesn't then the lifter will need to be replaced, that involves removing the head. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 2, 2012 Share Posted July 2, 2012 It's that knocking sound when I accelerate. I call it lifter rattle. Not sure what it really is. It gets faster as the engine revs but stops when I'm sitting still. The oil is good. The pressure is good. Oil pressure is about 40 at 65mph. I ideas? What brand of oil filter are you using? Link to comment Share on other sites More sharing options...
Virginia Posted July 2, 2012 Author Share Posted July 2, 2012 It's that knocking sound when I accelerate. I call it lifter rattle. Not sure what it really is. It gets faster as the engine revs but stops when I'm sitting still. The oil is good. The pressure is good. Oil pressure is about 40 at 65mph. I ideas? What brand of oil filter are you using? Whatever the Valvoline oil change place put in. Not sure. Link to comment Share on other sites More sharing options...
Virginia Posted July 2, 2012 Author Share Posted July 2, 2012 You can try putting in oil stabilizer or Mystery Oil to see if it will pump the lifter up. If it doesn't then the lifter will need to be replaced, that involves removing the head. That sounds complicated. I've never done it. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 2, 2012 Share Posted July 2, 2012 Get the brand name off the oil filter. Did you have this noise before the oil change? Link to comment Share on other sites More sharing options...
Virginia Posted July 2, 2012 Author Share Posted July 2, 2012 No and honestly, it's been a while since I've changed the filter. I just keep adding because I'm losing about a quart every 2 weeks or so from blow by. I'll take it in and have it changed. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 2, 2012 Share Posted July 2, 2012 No and honestly, it's been a while since I've changed the filter. I just keep adding because I'm losing about a quart every 2 weeks or so from blow by. I'll take it in and have it changed. Do it yourself. Use a Wix or Napa Gold filter. And, your blowby could be caused by clogged CCV hose from the rear top of the valve cover to the intake manifold. Really could be that simple. Link to comment Share on other sites More sharing options...
Virginia Posted July 2, 2012 Author Share Posted July 2, 2012 I check that little tube periodically. I'll check it again. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 2, 2012 Share Posted July 2, 2012 I check that little tube periodically. I'll check it again. If it's partially clogged, or the orifice is restricted, or the fitting on the intake manifold is restricted, it can cause blowby. Link to comment Share on other sites More sharing options...
Virginia Posted July 3, 2012 Author Share Posted July 3, 2012 I'll check it tomorrow. Happy to report that there was no rattle today when I drove it. Added Marvel Mystery oil to the crankcase. We'll see what tomorrow brings. Link to comment Share on other sites More sharing options...
Virginia Posted July 4, 2012 Author Share Posted July 4, 2012 Day 2. No lifter rattle. Link to comment Share on other sites More sharing options...
cruiser54 Posted July 4, 2012 Share Posted July 4, 2012 Good news. What about the "blowby" issue? Link to comment Share on other sites More sharing options...
Virginia Posted July 4, 2012 Author Share Posted July 4, 2012 I'm still working on that one. Link to comment Share on other sites More sharing options...
