A bit of help with a 99 Dodge Grand Caravan
whowey
My wife's bus has an issue.
Every so often all the gauges go dead and the ABS warning light come on. This will continue for a day or so and then everything goes back to normal.
When it happens the cruise control still works fine.
I have a feeling that it is a ground related issue from the symptoms, but I know there are some pretty good Chrysler techs on here. I sure would appreciate even a direction to look in...
the gauges usually die because of a broken solder connection on the back of the cluster. very common problem. had to fix that on my 97. I'll see if I can find the link that helped me.
