I'm needing to replace the LF Window regulator in Oscar. I was just wondering if the 97-01 manual regulators are a direct bolt in for the 84-96 style windows, I know the 97+ uses a full window but I don't know if that effects the regulator design or not.
thanks for any info! ;)
97+ XJ regulators are not a bolt in, but will work if you drill new mounting holes and shim certain of those holes properly. I'm guessing you're looking to do the full window conversion. For what it's worth, the Bejing XJ (power) window regulators fit the "old" style XJ door regulator holes exactly (because they use the older doors). You will require with these to create a simple mounting bracket to use the 97+ Xj window with them.
