mjtjnj Posted May 29, 2012 Share Posted May 29, 2012 Hey guys, I pulled my head because my rebuilder messed up installing the valve stem seals. I took the head off, then replaced it, but it was one of those heads (which I had never seen on Chevy's) that didn't have alignment pins. I used some studs, which I later learned are not precise enough to align it. And it leaks antifreeze. It's getting worse, and I have some time, so I'm going to pull the head again. Two things: 1. Can I get alignment pins?? 2. Can someone post the FSM pages (or link to) for the manifold and cylinder head torque sequences? I had a guy in my garage buying some parts a few months back, and he made off with my FSM. :fs1: Thanks-- Tom Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 29, 2012 Share Posted May 29, 2012 http://comancheclub.com/forums/viewtopic.php?f=2&t=1176&hilit=Head I've heard of guys cutting the heads off the old head bolts and using them for allignment. Link to comment Share on other sites More sharing options...
mjtjnj Posted May 29, 2012 Author Share Posted May 29, 2012 Thanks, Fiatslug. I also saw the FSM recommendation regarding new cylinder head bolts. Where would one buy a set of them? Thanks-- Tom Link to comment Share on other sites More sharing options...
fiatslug87 Posted May 29, 2012 Share Posted May 29, 2012 Where would one buy a set of them? Try rockauto.com Link to comment Share on other sites More sharing options...
mjtjnj Posted June 7, 2012 Author Share Posted June 7, 2012 Yeah, love them. In this case, no dice. :fs1: Link to comment Share on other sites More sharing options...
carnuck Posted June 7, 2012 Share Posted June 7, 2012 http://headbolts.com Found them looking for ones for the AMC Eagle Link to comment Share on other sites More sharing options...
flint54 Posted June 11, 2012 Share Posted June 11, 2012 Hesco has them as well: http://www.hescosc.com/shop.asp?action= ... catId=7735 Link to comment Share on other sites More sharing options...
