Jeep1121 Posted September 25, 2020 Posted September 25, 2020 On 5/21/2012 at 4:42 PM, cruiser54 said: Do the hazard flashers work? I'm having the same issue. except my hazards work. i changed the turn signal switch behind the steering wheel. any opinions. also winshield wipers do not work either. 1987 jeep comanche . 4.0 L V6 manual transmission
Tomanche Posted June 23, 2022 Posted June 23, 2022 Just got an 87 4.0 manual 4x4. Lots of problems! The only exterior lights that work are the headlights. No turn signals, hazards, running, tail, brake, reverse. No gauge cluster lights. The clock works but the hour goes up like it’s counting seconds. Speedo doesn’t work. The indicator lights left of gauges doesn’t light up. Blower only works on the 3rd setting. Radio needs to be rewired but works sometimes. Parking brake doesn’t work. 3rd and 4th gear are a little crunchy especially when downshifting. Plenty of other issues but that’s what I’ve found so far. Please help!
jdog Posted June 23, 2022 Posted June 23, 2022 Check the fuse box 35 minutes ago, Tomanche said: Just got an 87 4.0 manual 4x4. Lots of problems! The only exterior lights that work are the headlights. No turn signals, hazards, running, tail, brake, reverse. No gauge cluster lights. The clock works but the hour goes up like it’s counting seconds. Speedo doesn’t work. The indicator lights left of gauges doesn’t light up. Blower only works on the 3rd setting. Radio needs to be rewired but works sometimes. Parking brake doesn’t work. 3rd and 4th gear are a little crunchy especially when downshifting. Plenty of other issues but that’s what I’ve found so far. Please help! Also check the column to make sure it's connected, clock sounds oike the hour adjust button is stuck. Blower is the blower motor resistor or fan switch. Lots of info around, also start a build thread and add your Vin to the registry
Tomanche Posted June 23, 2022 Posted June 23, 2022 I changed all the fuses to new ones. New flasher and hazard relay. Unplugged and replugged in the column. Nothing changed. Also the rear passenger upper shock mount broke off. Not sure what to do with that. And it jiggles a little bit when it gets up to speed.
NickyV Posted October 15, 2023 Posted October 15, 2023 Definitely worth replacing the sockets/harnesses on each of the front turn signals. This resolved my always-on headlight indicators (always on when the headlights are on).
