jimoshel Posted May 17, 2012 Share Posted May 17, 2012 Has anybody replaced the calibration resistor in the tach circuit to use 4 cyl tachs in 6 cyl and vice versa? I'm thinking you can just replace the two fixed resistors with two of the proper resistance or swap in a trimmer pot. Searched search and couldn't find anything on the subject. Right now I have 3 instrument panels, one from a 2.5, 2.8 and a 4.0, on my desk getting ready to dismember them and see but don't want to rehash something if it's already been done. :dunno: Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 18, 2012 Share Posted May 18, 2012 My 4.0 to 2.5 tach has not been adjusted. Idle reads 450-500 when is should read 550-600. Not off by as much as everyone thinks. I live with it. Supposedly mine is adjustable, when I change the faces out to white I may adjust it then if I can find someone with a handheld tach.......if not screw it. Link to comment Share on other sites More sharing options...
jimoshel Posted May 18, 2012 Author Share Posted May 18, 2012 My 4.0 to 2.5 tach has not been adjusted. Idle reads 450-500 when is should read 550-600. Not off by as much as everyone thinks. I live with it. Supposedly mine is adjustable, when I change the faces out to white I may adjust it then if I can find someone with a handheld tach.......if not screw it. Or an audio generator. For a 6 cyl 100cycles per second will equal 2,000RPM. Or use a small transformer, 12VAC or less. 60CPS will translate to 1200RPM Link to comment Share on other sites More sharing options...
Eagle Posted May 18, 2012 Share Posted May 18, 2012 Has anybody replaced the calibration resistor in the tach circuit to use 4 cyl tachs in 6 cyl and vice versa? I'm thinking you can just replace the two fixed resistors with two of the proper resistance or swap in a trimmer pot. Searched search and couldn't find anything on the subject. Right now I have 3 instrument panels, one from a 2.5, 2.8 and a 4.0, on my desk getting ready to dismember them and see but don't want to rehash something if it's already been done. :dunno: The 4.0L tach should already have a potentiometer. The clusters from 1988 and newer do have it. 1986 and older do not, but a 2.8 is a 6-cylinder, so it will be properly calibrated for a 4.0L. 1987 is the question mark year -- I don't know if they had a potentiometer or not, or if it showed up as a mid-year change. Link to comment Share on other sites More sharing options...
Eagle Posted May 18, 2012 Share Posted May 18, 2012 My 4.0 to 2.5 tach has not been adjusted. Idle reads 450-500 when is should read 550-600. Not off by as much as everyone thinks. But it's not a fixed difference. What does a tachometer do? It counts revolutions. It does that by counting ignition pulses. For a 4-cylinder, 2 pulses = 1 revolution. But for a 6-cylinder, it needs 3 pulses for 1 revolution. So ... Take a 6-cylinder tachometer. In a 4.0L vehicle, 2100 RPM needs 2100 x 3 = 6300 ignition pulses. Now put that tach on a 4-cylinder. Run it up to where it reads 2100 RPM. That's still 6300 pulses, but in a 4-banger 6300 ignition pulses is 3150 RPM. It's not off by 100 RPM, it's off by 50 percent. Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 20, 2012 Share Posted May 20, 2012 I got a mechanic buddy with a shop down the road, I stop in next week and see if he has a way to test the rpms. Link to comment Share on other sites More sharing options...
alleydog Posted May 21, 2012 Share Posted May 21, 2012 Is there enough adjustment to read the correct rpm for a V8? I have an 89 comanche, and putting a 5.2 magnum in it. BTW, you could use a digital timing light to check rpm against a tach. Link to comment Share on other sites More sharing options...
