DREDnot Posted May 11, 2012 Posted May 11, 2012 My first Comanche,(my eighth Jeep). 2.5L low output, AW4 auto trans, 4.56 D35, A/C! 219k miles I'm scouring the local yards for the up market options. Got an ebay 2" spacer/shackle lift to go on it. Converted to laredo wingback buckets from a long trashed bench. Arizona Rust Free!!!
yellaheep Posted May 11, 2012 Posted May 11, 2012 Nice clean MJ! Those floor boards are incredible. :thumbsup: Are you sure about the 4:56 gear ratio in that D35? Never heard of anything from the factory, with an auto deeper than a 3:54/3:55. :dunno:
DREDnot Posted May 12, 2012 Author Posted May 12, 2012 I was surprised myself when I cleaned the crust off the axle tag...
yellaheep Posted May 12, 2012 Posted May 12, 2012 Albie Damm....... Ya learn something new every day. :thumbsup:
DREDnot Posted May 13, 2012 Author Posted May 13, 2012 I just happened to see this little quote on the Novak enterprises website in the aw4 page. "The AW4 and the 2.5L engine was a rare combination in the XJ / MJ model Jeeps as spec-to-build. They recieved 4.56 axle ratios."
Alexia Posted May 14, 2012 Posted May 14, 2012 I just happened to see this little quote on the Novak enterprises website in the aw4 page. "The AW4 and the 2.5L engine was a rare combination in the XJ / MJ model Jeeps as spec-to-build. They recieved 4.56 axle ratios." Yep! Helps to make up for the 2.5L being gutless. Double check under the firewall padding for rust. That foam likes to trap water and form rust.
