kawaboy13 Posted April 30, 2012 Posted April 30, 2012 I'm looking to upgrade my harness and put IPF headlight assemblys and IPF bulbs. What are the suggestions on bulbs and what wattage? I heard the fat boy bulbs are great. I put new sealed beams in and the street lights put out more noticeable light to me. Also is there going to be a difference in brightness on my taillights? You can tell when you hit the brake but they don't have the output of a newer vehicle. Anyone upgraded with the factory tails? Also some of the harnesses seem way cheaper than others, what is the best route to go? Thanks, John Paul
JENSSEN Posted May 1, 2012 Posted May 1, 2012 I have Hella's in all my driver jeeps,.. Big improvement with the stock bulbs,...
cruiser54 Posted May 1, 2012 Posted May 1, 2012 Bulb wattage in the 55-60 range is good. Hella and Phillips are good brands. For dual filament bulbs as in tail/turn signal/brakes, I use 2357s. They're a heavy duty version of the old 1157s and are brighter. I've tested them side by side at night. For single filament bulbs like reverse lights, I use 795 bulbs. They have the base of the old 1034 with a halogen globe on them. As for general brightness, it's always good to polish your lenses. I use Meguiar's plexiglass cleaner followed by their polish.
vaquaro Posted May 1, 2012 Posted May 1, 2012 First...go with an upgrade harness with relays ( eauto.com ) to eliminate voltage loss from thin wires carrying full load all the way from H/L switch to the lights . It's plug and play simple and the results are excellent . Along with Hella E-codes and standard H-4 bulbs you will have daylight any time you want :thumbsup:
kawaboy13 Posted May 4, 2012 Author Posted May 4, 2012 Does anyone know of a site I can order everything from all at one time? Also arent IPF lights the same quality as hella just cheaper?
cruiser54 Posted May 4, 2012 Posted May 4, 2012 Try poking around on www.eautoworks.com for the lights. The taillight bulbs I suggested can be purchased at Napa.
