relyt120 Posted April 25, 2012 Share Posted April 25, 2012 So I recently installed power windows and locks in my 89 Pioneer. Having removed the window crank I had a nice sized hole in the door panel looking ugly so I decided to make use of them! So I got to thinking...what does my truck need :hmm: , :eek: of course!-CUP HOLDERS!! It's really great to have somewhere to put my drinks now so I'll share this with you all! 8) Difficulty: Novice/really easy Here's what you need(per cupholder): A drill Drill bit 3 bolts(2 short 1 longer) 4 nuts some scrap metal, thinner is easier socket wrench to fit your nuts marker *tin snips (i used these to cut the scrap metal, you might not need) Cup holder<---- link Steps: Remove door panel. Cut your scrap metal to the appropriate size. place into the door and mark where the holes are. drill out the holes temporarily bolt the bracket in, mark the circle drill hole in center bolt bracket into the door, use short enough bolts to be able to get your wrench in there for full tightening(I used bolts from the Cherokee I got my Driver's fender from) place longer bolt through center hold with threads going out of the door, attach nut to hold it in re-install door panel drill hole in back of cup holder the size of your center bolt screw cup holder onto center bolt, enough to allow the final nut to go on secure with final bolt ENJOY. :thumbsup: :wrench: Link to comment Share on other sites More sharing options...
sinkrun Posted April 28, 2012 Share Posted April 28, 2012 Not bad at all! :thumbsup: Link to comment Share on other sites More sharing options...
87Chief Posted April 30, 2012 Share Posted April 30, 2012 Awesome! I must try Link to comment Share on other sites More sharing options...
relyt120 Posted May 3, 2012 Author Share Posted May 3, 2012 Thanks! It's pretty easy to do and i didnt even have to buy anything i didnt already have except the cup holder of course. Link to comment Share on other sites More sharing options...
richard Posted May 8, 2012 Share Posted May 8, 2012 i say great idea i have been thinking of putting cup holders on my 1989 4x4 comanche,but i like your idea . Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 9, 2012 Share Posted May 9, 2012 Good idea. :cheers: The black window/lock switch panel came from a 95-96 XJ, si? I like that better than the chrome/black older panels I used. Link to comment Share on other sites More sharing options...
relyt120 Posted May 12, 2012 Author Share Posted May 12, 2012 Good idea. :cheers: The black window/lock switch panel came from a 95-96 XJ, si? I like that better than the chrome/black older panels I used. You are correct, truthfully I am going to remove it since I have moved the switches to the dash where the clock should go. Link to comment Share on other sites More sharing options...
mikekaz1 Posted January 9, 2017 Share Posted January 9, 2017 I used those same cup holders but with the new style plastic door panels. Link to comment Share on other sites More sharing options...
