Akula69 Posted April 15, 2012 Share Posted April 15, 2012 Today, my son and I took down the gas tank on the Christmas Jeep as it was leaking fuel at the sending unit. After cleaning the tank and re-painting it, we replaced the main locking ring O-ring, and the smaller O-ring around where the wires go into the sending unit. Unfortunately, the unit still leaks around where the wires enter. I carefully removed the retaining nut and re-used it, but cannot seem to get it tight enough to seal against the O-ring. Hs anyone replaced this O-ring and used some other method of retaining nut? The origional one does not seem to work well. Thanks Jake Link to comment Share on other sites More sharing options...
pilecenturyfarm Posted April 16, 2012 Share Posted April 16, 2012 replaced my fuel pump this weekend and had a heck of a time getting it back on it... endend up getting it tight buy then coated the outside in silicone just to be safe.... po had a problem to cause it was covered in RTV and we had to scrape all that off to get it out :wrench: Link to comment Share on other sites More sharing options...
H8PVMT Posted April 19, 2012 Share Posted April 19, 2012 Manual says to get a new washer or use rtv on it Link to comment Share on other sites More sharing options...
ComancheKid45 Posted April 20, 2012 Share Posted April 20, 2012 You can usually get new Lock rings and O rings from any Auto Parts store, chances are it has been tweaked a bit. Remember the XJ (Cherokee) lock rings and o rings are the same as well ;) Link to comment Share on other sites More sharing options...
zekekb Posted April 20, 2012 Share Posted April 20, 2012 I went to the local auto parts store and purchased a new o-ring and a box of push nuts in assorted sizes. I also ran into the issue of not being able to get the new push nut close enough to the sending unit plate to get a seal. I ended up using a deep well socket that was just large enough to slip over the plastic stud where the electrical connections are. I then used a c-clamp to press the socket down onto the push nut, thus compressing the o-ring enough to create the seal. Link to comment Share on other sites More sharing options...
