zekekb
    West Georgia
zekekb's Achievements
Can Spell Comanche
Can Spell Comanche (2/11)
  1. I put Geolander 30s on mine with no issues. I did change out the lower control arms out with WJ lower control arms in preparation to installing larger tires.
  2. zekekb
    Making Memories
    I took my son and one of his buddies on a camping trip in the Appalachian foothills. I have a Ford Edge that is fully loaded with air conditioning, DC outlets for their games, a great stereo etc. The Comanche has just now gotten to a point where I can trust it to make it down the interstate without exploding. It has a bench seat, no A/C, crappy stereo, and the passenger side window gets stuck when rolled all the way down. As we were packing, I asked them, "Do you want to take the Ford or the truck?" They both replied "Lets take the Jeep!" It was cool seeing the boys wanting to rough it out. Well the Comanche made the 300+ mile round trip without a single hiccup. It ran just fine and used much less fuel than I had anticipated. I wanted to thank all of you for sharing the knowledge and passion for a pretty cool little truck. You all contributed to making memories for a couple of 9 year old kids. At the campsite Fishing for trout Worn out
  3. I used to drive Rangers exclusively. I actually lost sleep last night trying to decide if I should try a Ranger split bench. I would like more details please.
  4. I went to the local auto parts store and purchased a new o-ring and a box of push nuts in assorted sizes. I also ran into the issue of not being able to get the new push nut close enough to the sending unit plate to get a seal. I ended up using a deep well socket that was just large enough to slip over the plastic stud where the electrical connections are. I then used a c-clamp to press the socket down onto the push nut, thus compressing the o-ring enough to create the seal.
  5. Thank you gentlemen. Proper torque has been applied.
  6. I need to know the torque values for the WJ LCA transplant into my MJ. Is it 85 lbs on the axle side and 133 on the frame side? Thanks
  7. http://atlanta.craigslist.org/nat/cto/2704705441.html
  8. http://atlanta.craigslist.org/atl/cto/2655462579.html
  9. http://atlanta.craigslist.org/atl/bar/2653507838.html
  10. http://atlanta.craigslist.org/nat/cto/2623908787.html
  11. A friend of mine gave me his stock JK coils and shocks. Any chance I can use these on my MJ? Thanks 1988 Pioneer 4WD
  12. http://macon.craigslist.org/cto/2537098433.html
  13. I want to know where I can get one of those truck bed machine gun mounts.
  14. I would like to see your setup if you don't mind.
